Designie
I had my water tested recently and I am looking for some opinions on a couple of contaminants that were found. I believe they said that it is pretty hard water, very salty. But besides that, 3 volatile contaminants were found.
The 3 contaminants were:
Dichloromethane, Tetrahydrofuran and Xylene. My question is regarding the levels. I know in a perfect world there would be none of these detected, but are the levels found in my test of little concern or great concern? All 3 were barely above the minimum for detection. 0.003, 0.02, 0.002 mg/L respectively.
Here are the test results:
Aluminum ND mg/L 0.2 EPA Secondary 0.1
Arsenic ND mg/L 0.01 EPA Primary 0.005
Barium ND mg/L 2 EPA Primary 0.30
Cadmium ND mg/L 0.005 EPA Primary 0.002
Calcium 28.2 mg/L -- 2.0
Chromium ND mg/L 0.1 EPA Primary 0.010
Copper 0.013 mg/L 1.3 EPA Action Level 0.004
Iron 0.066 mg/L 0.3 EPA Secondary 0.020
Lead 0.002 mg/L 0.015 EPA Action Level 0.002
Magnesium 12.50 mg/L -- 0.10
Manganese 0.016 mg/L 0.05 EPA Secondary 0.004
Mercury ND mg/L 0.002 EPA Primary 0.001
Nickel ND mg/L -- 0.020
Potassium 5.2 mg/L -- 1.0
Selenium ND mg/L 0.05 EPA Primary 0.020
Silica 9.460 mg/L -- 0.100
Silver ND mg/L -- 0.002
Sodium 514 mg/L -- 1
Zinc 0.013 mg/L 5 EPA Secondary 0.004
Physical Factors
Alkalinity (Total) 210 mg/L -- 20
Hardness 120 mg/L 100 NTL Internal 10
pH 7.7 pH Units 6.5 to 8.5 EPA Secondary
Total Dissolved Solids 1500 mg/L 500 EPA Secondary 20
Turbidity 0.8 NTU 1 EPA Action Level 0.1
Inorganic Analytes - Other
Contaminant Results Units National Standards Min. Detection Level
Chloride 620.0 mg/L 250 EPA Secondary 5.0
Fluoride 1.7 mg/L 4 EPA Primary 0.5
Nitrate as N ND mg/L 10 EPA Primary 0.5
Nitrite as N ND mg/L 1 EPA Primary 0.5
Ortho Phosphate ND mg/L -- 2.0
Sulfate 170.0 mg/L 250 EPA Secondary 5.0
Organic Analytes - Trihalomethanes
Bromodichloromethane ND mg/L -- 0.002
Bromoform ND mg/L -- 0.004
Chloroform ND mg/L -- 0.002
Dibromochloromethane ND mg/L -- 0.004
Total THMs ND mg/L 0.08 EPA Primary 0.002
Organic Analytes - Volatiles
Status Contaminant Results Units National Standards Min. Detection Level
1,1,1,2-Tetrachloroethane ND mg/L -- 0.002
1,1,1-Trichloroethane ND mg/L 0.2 EPA Primary 0.001
1,1,2,2-Tetrachloroethane ND mg/L -- 0.002
1,1,2-Trichloroethane ND mg/L 0.005 EPA Primary 0.002
1,1-Dichloroethane ND mg/L -- 0.002
1,1-Dichloroethene ND mg/L 0.007 EPA Primary 0.001
1,1-Dichloropropene ND mg/L -- 0.002
1,2,3-Trichlorobenzene ND mg/L -- 0.002
1,2,3-Trichloropropane ND mg/L -- 0.002
1,2,4-Trichlorobenzene ND mg/L 0.07 EPA Primary 0.002
1,2-Dichlorobenzene ND mg/L 0.6 EPA Primary 0.001
1,2-Dichloroethane ND mg/L 0.005 EPA Primary 0.001
1,2-Dichloropropane ND mg/L 0.005 EPA Primary 0.002
1,3-Dichlorobenzene ND mg/L -- 0.001
1,3-Dichloropropane ND mg/L -- 0.002
1,4-Dichlorobenzene ND mg/L 0.075 EPA Primary 0.001
2,2-Dichloropropane ND mg/L -- 0.002
2-Chlorotoluene ND mg/L -- 0.001
4-Chlorotoluene ND mg/L -- 0.001
Acetone ND mg/L -- 0.01
Benzene ND mg/L 0.005 EPA Primary 0.001
Bromobenzene ND mg/L -- 0.002
Bromomethane ND mg/L -- 0.002
Carbon Tetrachloride ND mg/L 0.005 EPA Primary 0.001
Chlorobenzene ND mg/L 0.1 EPA Primary 0.001
Chloroethane ND mg/L -- 0.002
Chloromethane ND mg/L -- 0.002
cis-1,2-Dichloroethene ND mg/L 0.07 EPA Primary 0.002
cis-1,3-Dichloropropene ND mg/L -- 0.002
DBCP ND mg/L -- 0.001
Dibromomethane ND mg/L -- 0.002
Dichlorodifluoromethane ND mg/L -- 0.002
Dichloromethane 0.003 mg/L 0.005 EPA Primary 0.002
EDB ND mg/L -- 0.001
Ethylbenzene ND mg/L 0.7 EPA Primary 0.001
Methyl Tert Butyl Ether ND mg/L -- 0.004
Methyl-Ethyl Ketone ND mg/L -- 0.01
Styrene ND mg/L 0.1 EPA Primary 0.001
Tetrachloroethene ND mg/L 0.005 EPA Primary 0.002
Tetrahydrofuran 0.02 mg/L -- 0.01
Toluene ND mg/L 1 EPA Primary 0.001
trans-1,2-Dichloroethene ND mg/L 0.1 EPA Primary 0.002
trans-1,3-Dichloropropene ND mg/L -- 0.002
Trichloroethene ND mg/L 0.005 EPA Primary 0.001
Trichlorofluoromethane ND mg/L -- 0.002
Vinyl Chloride ND mg/L 0.002 EPA Primary 0.001
Xylenes (Total) 0.002 mg/L 10 EPA Primary 0.001
Does anyone have an opinion on how much I should be concerned about these contaminants and to what I degree I should try to treat them?
Thanks in advance.
Ron.
Physical Factors
Thanks in advance.
Ron.
