Softener causing pressure issues.
Jason Kay
West Orange, New Jersey
Hi. I've been experiencing water pressure issues and have isolated it to the water softener (I bypassed the softener and the pressure issues were gone).
Before I call a plumber, can anyone suggest how to resolve? I don't have a user manual and I'm not very familiar with how these things work. Attached are pics of my unit. Thank you very much.
City water? That is harder on resin. Resin is probably shot, so replacing the resin is a possibility.
You have a timed softener.You would could be better off buying a new 1.5 cuft demand softener with a 10x54 inch tank and 10% crosslinked resin, and I say that not knowing your water.
You may be better off just swapping in new resin. A 9x48 tank takes 1 cuft of resin, and a 10x54 takes 1.5 cuft.
Jason Kay
You have a timed softener. You would probably be better off buying a new 1.5 cuft demand softener with a 10x54 inch tank and 10% crosslinked resin, and I say that not knowing your water. That gets you new resin plus a new on-demand softener.
Yes, city water ,not well water.
ditttohead
Water systems designer, R&D
Ontario California
That is a Fleck original valve, these systems can be rebuilt for decades. Does the timer go back to home? In the picture it is in regeneration. You can easily replace the resin.
Water Guy
New York
2 people in the home, but i'd want for a larger family (empty nesters). Don't know hardness, but I'm in northern NJ.
empty nesters? I'm assuming that means 2 people with occasional family visits? determining water hardness is crucial to properly setting up the new equipment if that's the route you're leaning toward. can you smell chlorine in the water?
Jason Kay
Exactly. Found the hardness on the town website: Water Hardness Between: 80 to 180 Parts Per Million
(6 to 10 Grains Per Gallon)
1 cuft or 1.5 cuft would do the job.
Planning for new softener, or swapping resin?
ditttohead
Ontario California
10 GPG with 2 people in the house, 1200 grains used per day is a decent guess. Your system is small but it will work fine for your application. If the valve is good, and the tank is fine, replace the resin with a better quality resin. If you want the resin to last much longer, adding a backwashing carbon tank ahead of the softener will greatly increase your resin bed life.
Water Guy
New York
a new metered control head may be more suited to your new needs. it regenerates based on water consumption so would be more efficient on salt usage. seems that system has treated your needs for some time to your satisfaction, so consider a fleck 5600 mechanical metered control head as a replacement. 36000 grains should be sufficient for your needs. you can set it at 10 lbs salt dosing and regen at around 1500 gallon intervals. the current control head may be more trouble (costly) than a new head of you don't know how to repair it. I'd also suggest a cartridge carbon filter installed prior to the softener if chlorine is present as it will extend the life of the Media.
Jason Kay
Thanks. You're referring to this https://www.amazon.com/Fleck-Metered-Softener-Demand-Control/dp/B004N7XKL2 ?
I'd also have to replace the resin in the tank, correct?
Bannerman
Ontario, Canada
From what I see in the photos, a Fleck 5600 mechanical metered control head is what he already has.
As Ditttohead suggested, you can rebuild your existing control valve and replace the resin and bedding gravel in your existing tank.
Water Guy
New York
I'm aware but, from his statement on not knowing about the system, as well as other components that may be worn, it would probably be more prudent (and less costly overall) to just get a new control head. in a perfect world I agree with you his assessment of just new mineral and addition of some type of carbon filtration.
Bannerman
Ontario, Canada
Curtis, a previous commentor stated he has a 'timed softener' (non metered). You appeared to be confirming that incorrect assessment based on your comments in #14.
Water Guy
New York
yes. it's an exact replacement to your current. yes, new mineral would be required, however, it's not as easy to replace as it may sound. emptying can be a bear if you haven't done it. it depends if you want to go diy route or relatively plug and play. if relatively plug and play is the choice, consider buying with tank and resin.
Charlie Bosco
Active Member
Florida
Is the reason City Water is harder on resin only due to the chlorine? I heard high chlorine can turn your resin to mush.. Mush would def cause flow issues. If not Chlorine but just calcium, is it possible his backwashes are not getting the resin cleaned (whether due to proper brine or BW flow) and its just building up to the point of restriction?
I think he should try and run a ton of Res Care through it.. I brought a 10 year old DEAD Kinetico back to life with back to back washes. I went through the entire $13 Gallon ResCare in a week.. The water is now slippery soft like a brand new WS. Kinetico wanted $400 to rebed and I thought I cant hurt the resin any worse than it was. So glad I tried that first.
