shower valve plumbing question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ragtop68rs, Dec 15, 2013.
  1. ragtop68rs
    ragtop68rs New Member
    Dec 15, 2013
    Grand Rapids,Mi.
    Guys, I'm starting a master bath remodel. For my shower I want to use the moentrol 3320(IPS)or 3330(CC) valve. My plumbing is all pex. Could I use either one of these and just use adapters to change to pex? Would one be better or easier to use than the other? Thanks, John
  2. Terry
    Aug 17, 2004
    Not much difference between the two.
    The tub spout needs either copper or pipe.
    No PEX or PEX fittings to the tub spout.
    The valve must be sturdy in the wall. PEX can allow too much flex, so if running PEX, secure the valve in there solid.
  4. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    I just installed two moentrol valves this week in a remodel. Not much in the way of mounting provided on the valve, so I "stub" them out with copper to give me something to mount with. then you could transition to pex if you so desire.
  5. jm66208
    jm66208 Member
    Aug 17, 2011
    Kansas City
    Here's a pic terry showed me recently of a tub install. I don't carry a camera. Note his rough in. Do it like he did, securing the valve with copper pipe. just transition to pex below the lower 2 x 4 brace he put in.
  6. ragtop68rs
    Dec 15, 2013
    Grand Rapids,Mi.
    Thanks guys, that is what I will do.
Similar Threads: shower valve
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Moen Shower Valve is stiff. Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Replacement Shower Valve Jan 2, 2017
