Shower drain on basement remodel
Discussion in 'Shower & Bathtub Forum & Blog' started by PattiS, Nov 26, 2013.
  1. PattiS
    PattiS New Member
    Nov 26, 2013
    Rockville, MD
    I am new to the forum but have found lots of good stuff here. Now I need help for my unique situation. I removed the mortar shower pan and plan on replacing it with a mortar and tile one. The plumbing is an issue. It is a pipe with a flange welded on it. I was hoping to just float the mortar pan around it but I assume I will need a liner. My question is do I need to redo the piping to install a three piece drain (which will mean knocking out some of the slab) or is there a way to seal the pan around the pipe so I don't have bigger problems later with the slab? Here are a few pictures of the situation:
  2. Terry
    Aug 17, 2004
    Normally we would knock out some of the slab, and install a new clamping shower drain.
    Not a big deal to do that.
    I suppose you could also find something for that top of that and screw that down with Silicone. If it's mine though, I'm thinking total replacement. Everything builds off of that.
  4. PattiS
    PattiS New Member
    Nov 26, 2013
    Rockville, MD
    Thanks, Terry. I was hoping not to cut into the slab, I don't feel that confident in my ability to do that. I may need to hire someone.
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Post(s) removed by John Whipple
  6. PattiS
    PattiS New Member
    Nov 26, 2013
    Rockville, MD
    There wasn't anything other than what you see when I took the shower pan out around it other than the strainer on top. There are no bolts or bolt holes and the collar is welded to the pipe.
  7. Terry
    Aug 17, 2004
    You can tap out the concrete with a sledge hammer.
    There will be room to throw a coupling on. If not, it's not a big deal to change out the p-trap at the same time.
  8. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Nobody "welds" a drain into a pipe. It might be poured lead, but the drain is not welded to the pipe.
  9. hj
    Drains with that type of top usually DO have a clamping ring, but it may be just under the concrete/mortar cap.
Similar Threads: Shower drain
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Yesterday at 2:58 PM
Shower & Bathtub Forum & Blog Odd Shower Drain Rough In Mar 5, 2017
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
