shower drain - is this gap normal?
Discussion in 'Shower & Bathtub Forum & Blog' started by dgold, Aug 18, 2013.
  1. dgold
    dgold Product R&D
    Dec 6, 2006
    Product R&D - Swimming Pool Industry
    Carlsbad, CA
    Below are two pictures of my 2nd floor shower drain. Is this gap supposed to be there, or should there be some sort of o-ring / gasket / caulking in there?
    [​IMG][​IMG]
    I've cleaned this up with Bleach/Water, then Bar Keeper's Friend using a stiff brush. It's not fully cleaned, but I've uncovdered this gap, and am wondering if it should or shouldn't be there, or if I need to seal it up.
    I have some sort of leak which is staining the ceiling of my 1st floor kitchen. Fortunately, we've got other bathrooms, so we've been able to not use it for several days now, but I'd prefer not to open up my ceiling to fix the drain if at all possible.
    Lastly, if I remove the grout around this drain, is it replaceable from the top? I might even have an extra sheet of tile.
    Thanks in advance.
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Looks like you have a clamping drain and perhaps a hot mop shower waterproofing system.
    Not familiar with that drain but if you do have a hot mopped shower then you most likely have 1.5"- 2" of mortar above your hot mop. A O ring would not improve the function of the drain if this is so but might keep things a little cleaner. If you have staining from this shower then perhaps you have a leak some where.
Similar Threads: shower drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
