Should I Rebuild or Replace My Old Moen Shower Valve with Parts from the New Kit?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jeff S, Dec 18, 2013.
  1. Jeff S
    Jeff S New Member
    Dec 18, 2013
    Houston, TX
    I am remodeling a bathroom and have everything torn down to the studs. I removed the old Moen hardware and bought a new tub/shower kit to replace the old hardware. The new kit also came with the mixing valve. Both the new and old valves are the Posi-temp style. My question... The old valve is about 12 years old and is working fine, is it worth rebuilding or replacing that valve with the parts from the new kit while I have an open working space?
    Thanks in advance for your help.
    Jeff
  2. hj
    The valve body its self is "dumb". It doesn't know what parts you are putting into it, so you can use the new parts as long as they fit.
  4. Terry
    Aug 17, 2004
    [​IMG]
    I pull the cartridge when I solder. You can use the new cartridge in the old brass, or not :) Your choice.
  5. Jeff S
    Jeff S New Member
    Dec 18, 2013
    Houston, TX
    Sounds great, thanks for the response!
Similar Threads: Should Rebuild
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Valve Stem Leak. Should I be worried? Sep 22, 2016
