Shires Thermostatic control knob
Discussion in 'Shower & Bathtub Forum & Blog' started by mihevi, Feb 18, 2014.
  1. mihevi
    mihevi New Member
    Feb 18, 2014
    Scotland
    Hi Everybody,
    I found your forum when looking for Shires Thermostatic shower control knob.
    I spent already several weeks searching and checking Internet and with local shower shops and almost lost hope to do so.
    All shower system is fine only the plastic part (plastic teeth) wear out.
    Do you know where I can it new or used or what's the product code or if there is any replacement which could fit? Any help more then welcome.
    Pictures which may help to identify it:
    - mounted shower control knob
    https://dl.dropboxusercontent.com/u/36797542/IMG_2495.JPG
    - inside of control knob
    https://dl.dropboxusercontent.com/u/36797542/IMG_2501.JPG
    - faulty control knob
    https://dl.dropboxusercontent.com/u/36797542/IMG_2504.JPG
    Thanks.
  2. thomasWshea
    thomasWshea New Member
    Feb 13, 2014
    software development
    WA
    I've had bad luck with replacement parts on anything typical consumer grade plumbing faucet / shower control from home depot or like stores. You can try a local plumbing supply house. Sometimes I can find parts at McMaster-Carr if it's a bushing or a seal. It looks like you have geared part that's worn, it could be a common part. If it isn't, try to press the manufacture. Some of them will help you out, and just send you a new assembly just because you asked. But there's a decent chance you won't get anywhere, so you'll be left with the choice or replacing it with something else that's disposable, or going with a higher end item such as ToTo, where they have rebuild-able / serviceable items that will list for decades. Personally, I'm tired or re-buying things, so I tend to replace what i have with upper end faucets and shower controls as the need arises.
  4. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
Similar Threads: Shires Thermostatic
Shower & Bathtub Forum & Blog Extracting stuck partial thermostatic cartridge sleeve due to mineral deposits Oct 5, 2016
Shower & Bathtub Forum & Blog Kohler DTV Thermostatic Valve Systems Aug 31, 2015
Shower & Bathtub Forum & Blog Hudson reed thermostatic shower valve Aug 27, 2015
Shower & Bathtub Forum & Blog Kohler 3/4" Thermostatic Mixer Valve K2976 (stacked) Jul 30, 2015
Shower & Bathtub Forum & Blog Thermostatic mixing valve - hot water only? May 26, 2015
