Shark bite
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by plumberwanabe, Sep 28, 2012.
  1. plumberwanabe
    plumberwanabe New Member
    Apr 12, 2010
    Bellevue WA.
    Is it permitted to use 3/4" drop ear shark bite for hot water tank supply behind the wall?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Sure, why not? I'm pretty sure that the stainless steel ring with the teeth in it that holds the pipe in place probably won't dig into the pipe as it expands and contracts and loosen up over time. How do you feel about that?
  4. Terry
    Aug 17, 2004
    Shark bites are allowed behind the wall for plumbing.
    The only place you wouldn't use a sharkbite drop ear is if someone is running PEX to a tub spout. There you would use something like copper pipe to the drop ear for a tub spout, and the that sizing would work for a tub spout.
    But nothing else in the home has that restriction. A sharkbite drop ear in the wall for a water heater would be fine.
    Most plumbers prefer them to be exposed though. It does have moving parts that can fail.
    I have a few sharkbites in the vans, but they are rarely used. I mainly use copper sweat fittings and PEX fittings with compression rings.
Similar Threads: Shark bite
Plumbing Forum, Professional & DIY Advice Shark bites Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Sharkbite leak on PEX Dec 5, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite vs EPC or Mueller Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Warning!! Sharkbite fitting corroding May 17, 2016
