Also, should I be worried about the range of the pressure switch working between 48-50 psig, i.e. should I try to get it back to 40-60?
You should have added air to the tanks at this point.Using a tire gage, I got zero pressure on both tanks.
You will always get water when the pump is on, even if the tanks are waterlogged.Turning the pump back on, I got some water at my house almost right away and slow flow started up the hill at their house around 25 psig.
YesSo I think I should have had pressure in both tanks when I bled down (precharge). Since I did not, should I pressurize them with a compressor?
If you have a tire valve type nipple on the top of the tank, you have a bladder tank.I do not know if there is a bladder in these tanks or not.
I don't see how this is possible with zero pressure in the tanks...Remember that my pump cycles over several minutes even under large usage, so I don't see a problem there. Thank you
I think you hit the nail on the head, it must be a sticking check valve (or some other obstruction)...It is not a slow return of pressure to their house; it goes from no flow at all to normal flow when it comes back on. Note from previous posts that with continuous water on at their house, and turning power to the pump off, they have flow all the way down to 25 psig at least, slowing, but still flowing. "a sticking check valve seems logical"
IIRC you lose .433 psi per foot of elevation above the pressure tank tee to their highest fixture. So 27*.433= 12' elevation, is that about right to the fixture they are using when the water shuts off?
