Hi,
Well, I am back to the source of all well knowledge, but this time for a friend. He inherited a cabin in the woods that has a two inch well at 30 feet deep. the static water level is at 4 feet below land. It was pumped 2 1/2 hours at 10 gpm and the water was at 21 feet below land back in 1986. He has a 60 gauze screen, four feet in length and set between 26 and 30 feet.
OK, his problem is that the Sears Vertical Casing Adapter at the top of the well pipe is leaking a lot. He would like to fix it himself but does not know what that would entail. He is considering changing the tank and pump as well, so the question (finally) is what would be the optimal way to approach this situation? Would he be further ahead just replacing the adapter and leaving the rest alone, or could he see a noticeable improvement in water supply by revamping the system and eliminating the current two pipe adapter and converting to a shallow well pump with just the single pipe going in to the adapter?
Thanks in advance for any suggestions and advice!
