seeking most aggressive flush possible
Discussion in 'Toilet Forum discussions' started by soopergrape, Feb 3, 2008.
  1. soopergrape
    soopergrape New Member
    Feb 3, 2008
    I am seeking the toilet/flush mechanism with the most powerful, clog resistant combination possible (within reason...$$$). I don't care about looks, sound level, or anything else. If there is a system with unclogging jets, that would be a consideration. I have an individual who consistently clogs every toilet he has ever used. I don't want to end up with a jet powered overflow! :confused:
  2. Cass
    Cass Plumber
    Nov 12, 2005
    What $$$ amount is within reason???
  4. mysticturner
    mysticturner New Member
    Jan 28, 2008
    Outside Dallas TX
  5. jimbo
    jimbo Plumber
    There may not be a perfect answer to this. On recommendation might be to install a commercial flushometer valve toiler. The toilet plus valve will run $500 +. Another expenze will be that you will have to have a 1" water supply pipe run all the way from the main valve to the toilet. The flushometer valve will not work otherwise.
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I had an old AS powered by the Flushmate pressure-assist unit:
    http://www.flushmate.com/
    and recommend it highly. Very noisy, but very effective. The newer models are said to be quieter, but I wouldn't bet on it. When you flush one of these babies, there's no doubt where the poop is going. Several toilet manufacturers use this in their PA models.
  7. soopergrape
    Feb 3, 2008
    Seeking the Cruisinart of solid waste disposal
    500$ is doable. 1000$ is much less so. I'd hate to invest too much into something that may not be a positive selling point to a future buyer:
    "This here terlet sounds like a Double AA Nitro fueled dragster comin' off the line, but it sure don't leave no floaters! Oh, and you don't wanna be sittin' there when you fire this puppy up..." :eek:
    While I am all for performance and award zero points for style, a construction site style Port-A-Pottie would not be acceptable-and there are those weekly visits. If it can't be done with water I could stick an Incinerette (or whatever those electric ones are called) in the garage and take it on trips and when I move. Thanks.
  8. Terry
    Aug 17, 2004
    If you want to flush a tennis shoe down,
    get a Caroma.
    Trapways on those are larger than 3"
  9. soopergrape
    Feb 3, 2008
    Thanks, The Caroma seems to be just the thing. Do they come with power flush? I'll be checking out an Elliot's anyway, I'm also in the Dallas area.
    "If you want to flush a tennis shoe down..."
    I think I've found a kindred spirit! They are almost that tough, I've got one soaking in dishwasher detergent, too late for a fisherman.
  10. mysticturner
    Jan 28, 2008
    Outside Dallas TX
    I talked with Brett D. at the Plano store. He was suggesting a Toto, but I insisted on the Caroma. By his own admission, he suggests the Toto Drakes because he knows them and doesn't know much about the Caroma. In his defense however, he seemed genuinely interested in finding out why I wanted the Caroma over the Toto and what the differences were.
  11. Cass
    Cass Plumber
    Nov 12, 2005
    For what its worth...I have installed quite a few of them (Caromas) with no complaints...that said they do have a small water spot as do many of the new toilets.
    Like on of my customers said in jest...WoW, I can cancel my trash service now because what ever I put in it disappears.
  12. Maximus57
    Maximus57 New Member
    Feb 8, 2008
    With some of the "high powered toilet systems" does anything need to be reconstructed in my plumbing? Can they just replace my existing toilet without doing anything else? Also, what did you mean by small water spot? Are you speaking of the amount of water in the bowl?
  13. jadnashua
    A few toilet valves need a large water supply pipe - think the commercial ones. If it is a pressure assisted toilet, or any 'typical' toilet, no, the supply is the same as you have on your existing toilet. Depending on the style of the toilet, the location of the toilet's supply line might need to be in a specific place. For example, some of the Toto's need to have the supply further from the toilet centerline than others. The Toto's with the skirt that covers most of the toilet need the supply installed out wider.
Similar Threads: seeking aggressive
Toilet Forum discussions Seeking advice on changing the fill valve of a Toto Pacifica CST804S Dec 29, 2015
Toilet Forum discussions Crane Walsan wall-hung toilet, Seeking a flush handle ... Nov 11, 2015
Toilet Forum discussions Seeking a plumber in Nashville, TN to install a Toto toilet Jan 2, 2015
Toilet Forum discussions Desperately seeking parts for a Caroma Toilet - need dual flush seal washers Mar 11, 2011
Toilet Forum discussions Seeking any advice on bad smell, PLEASE HELP!!! Oct 3, 2010
