Pmaru77
I'm remodeling a bathroom right now and am trying to figure out these mini water heaters and what to do. First off, the bathroom sink, it takes too long and we waste water waiting for the hot. I've installed the Armitron before with great results. They were like 4 gallon electric water heaters under the sink inside a vanity or such. The problem with those, is the emergency overflow that needs to be dumped outside (I believe). Can the dump into the drain? Probably not. The second option is these in the wall tankless water heaters (electric) that can easily be fitted almost anywhere, provided you can get a 20 or 30 amp power line to it. They have no overflow dump valve to worry about. Either one of these would save me water, but add to the electric. Seeing that the future of water looks grim, and that electricity can eventually be from solar, I still want to do this for the sink.
Question, for a bathroom sink, I think I would hook up a cold water line to it? So that is the sink (easy decision).
For the shower, right now we occasionally bucket the excel cold water down the stairs and use it for the pool or garden (some work involved) plus there is only two of us. If we are diligent, that is the best of the best. But since I have everything apart and see that they make tankless water heaters that fit inside the wall, I'm tempted to hook up one of these, and have no idea if I would hook up the hot line or the cold line of water. It would depend on the tech. of the heater I'm guessing. To do or not to do? Me thinks these heaters are not proven to last? Plus you need a access door which I'm OK with. It would be nice if they worked. Any help out there?
