Resaurant Sink Drains, did I screw up? ABS vs Copper
Discussion in 'Plumbing Code Questions' started by SacCity, Mar 27, 2011.
  1. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    I went to a restaurant last week and had to rebuild the drain on their bar sink which drains into a floor drain.
    It was 1-1/2" copper with tight 90's and no clean outs. The bartenders keep dropping straws down the drain and clogging them. And there is no easy way to repair.
    I rebuilt the drain long sweeps, clean outs etc.... All good but I used ABS pipes.
    Now that I've walked home and am thinking about it I wonder, about half of the restaurants seem to have copper, and the other half ABS.
    Just because they use ABS does not mean that it's valid.....
    Thanks Mike
  2. Terry
    Aug 17, 2004
    I prefer plastic and ABS for restaurants, at least for in the bar. Copper perforates after a while in those locations.
  4. Plumber1979
    Plumber1979 Certified Plumber
    Jul 15, 2012
    Certified Plumber
    Ontario
    should be PVC DWV SYS 15
  5. hj
    quote;
    SHOULD BE? Why? I have not used a single piece of PVC DWV pipe or fittings in the 40 years I have been in this area, but HAVE installed many commercial and bar sinks using ABS.
    Correction. I did use PVC for a laboratory sink drain because they were using chemicals that melted ABS but not PVC.​
Similar Threads: Resaurant Sink
Plumbing Code Questions Venting using a horizontal drain from kitchen sink OK? Dec 16, 2016
Plumbing Code Questions Kitchen sink vent and large window Jul 21, 2016
Plumbing Code Questions Increase Height of Sink Drain for Vessel Sink May 7, 2016
Plumbing Code Questions Toilet waste line setup sink upstream of toilet? Feb 21, 2016
Plumbing Code Questions Sink pop-up required? Sep 8, 2015
