Replacing Kitchen Sink cabinets
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sethramesh, Jul 20, 2007.
  1. sethramesh
    sethramesh New Member
    May 12, 2007
    How difficult is this job? I need to replace my sink cabinet in kitchen.
    Do you I have to remove the plumbing - copper pipe etc that comes from the basement completely before putting a new cabinet? Any ideas, instructions on how to do this?
    Thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Cabinet work requires some experience which, judging by your question, you do not have. The difficulty depends on several factors, but revamping the plumbing does not rank very high on the list. I'm sure you want a good looking cabinet, so it would be my suggestion that you have a professional cabinet person do the job.
  4. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Depends on where the plumbing is - take a pic and post it...
  5. jadnashua
    As said, if the plumbing comes up through the floor of the cabinet, it's one thing, if it all comes out from the back wall, it's another. Some kitchen cabinets have a back wall, some don't. If yours does not have a back wall and the pipes come out of the wall, then it's fairly easy. Are there other cabinets next to it? Is there an existing counter you have to deal with?
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Those are actually the major questions here. Some cabinets are modular, meaning sitting side-by-side and connected at the styles where the hinges are attached, but other cabinets are more like "built-in", having a continuous front face from one end to the other. Then, either type is usually sitting under a full-length countertop.
    Knowing more about what might be wrong with you present cabinet would make it easier to suggest a specific approach.
  7. sethramesh
    May 12, 2007
  8. Terry
    Aug 17, 2004
    You will need to remove the copper pipe coming from the floor of the cabinet.
    After you have installed the new cabinet, you can drill down for the new pipes.
  9. sethramesh
    May 12, 2007
    Even though I have a basement, the pipe is not accessible from down. It is sandwiched between the concrete wall and a 2X10 beam. I guess I need to cut the pipe above, and align the cabinet hole to the pipe.
  10. jimbo
    jimbo Plumber
    Are you replaceing all the cabinets? In which case this is straightforward. You seem to imply replacing only the sink base. It must be lifted up over the pipes, so of course the counter top has to go.
  11. sethramesh
    May 12, 2007
    Yes; I am replacing all - Cabinets, Counter Top and the fixtures.
  12. markts30
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    When you are replacing the copper piping you cut out to remove the cabinet, get rid of the saddle tap on the cold line - put a proper tee in or a double outlet angle stop...
    The 1/4" line will have to be remove for the cabinet removal as well...
  13. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I would delay doing any serious cutting of the pipes until the cabinets are removed. Since you're replacing everything, it's a much simpler job -- just cut the cabinets away from the pipes. Once everything is cleaned up, you can start on the real problem, that of installing the new cabinets. I would cut the pipes well above the floor level of the cabinet, then just cut holes in the floor of the new cabinet and lower it down over the pipes, as you suggested earlier. Finally, add proper fittings to the stubs and you're done. There are several options for neatening-up the holes in the cabinet floor.
  14. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    I just did a job exactly like this. I carefully using the tip of the sawzall cut around the pipes and broke up the cabinet and removed it from the kitchen. Then I carfully cut the boards that were still hanging around the pipes.
    The difficult part will be putting in the new cabinet. You likely to have to open some pretty precise holes.
    I was going to suggest a bump out sink but it doesn't appear to be an option for you because your kitchen turns immediately after the sink.
    Tom
Similar Threads: Replacing Kitchen
Plumbing Forum, Professional & DIY Advice Replacing Old Kitchen Faucet - Putty or Silicone Jun 14, 2016
Plumbing Forum, Professional & DIY Advice Very low water pressure after replacing kitchen faucet and no hot water in shower May 15, 2014
Plumbing Forum, Professional & DIY Advice Help replacing hose on unknown kitchen faucet Mar 25, 2014
Plumbing Forum, Professional & DIY Advice Replacing Kitchen DWV Under Window Dec 13, 2013
Plumbing Forum, Professional & DIY Advice Replacing Kitchen Faucet Apr 10, 2012
