replacing irritrol transformer
Discussion in 'Irrigation / Sprinkler Forum' started by craniac, Aug 23, 2007.
  1. craniac
    craniac New Member
    May 12, 2007
    My sprinklers didn't come on this Spring, so after replacing a few things I finally put a multimeter on the transformer and it is dead.
    Is it hard to swap in a new transformer? My irritrol transformer unplugs from the wall, so no danger of frying myself. Do I have to buy the replacement from irritrol or can I score something from Radio Shack? Thanks for any advice. My crumbling brown lawn thanks you as well.
  2. Rancher
    Rancher Guest
    Radio Shack may have one, or you can score one cheap on E bay. The things to match is the Voltage, AC/DC it's probably AC, and the VOLT-AMPS or VA or Watts. Also there are many on-line electronic supply store, such as Jameco, or Digikey, All Electronics come to mind.
  4. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Most sprinkler systems can run from a 24VAC wall wart rated at 20 VA. That's enough power for two solenoids. (one zone valve and one master valve)
  5. craniac
    craniac New Member
    May 12, 2007
    Ah, I realized I was using the wrong setting on my multimeter. The Transformer is fine, but no power is going to the stations from the posts when I turn them on. So I will probably just replace the entire box.
Similar Threads: replacing irritrol
Irrigation / Sprinkler Forum Please help replacing my backflow preventer on my sprinkler system May 27, 2013
Irrigation / Sprinkler Forum No pressure on pop-up lawn sprinklers after replacing them Sep 20, 2011
Irrigation / Sprinkler Forum Replacing a Goulds J10S 1 hp pump for home sprinkler system Jul 6, 2010
Irrigation / Sprinkler Forum Replacing female copper fitting May 21, 2010
Irrigation / Sprinkler Forum Replacing Vacuum Pressure Breaker Aug 28, 2009
