DanM
I had a plumber stop by today to provide a quote for the bathroom remodel. He wants to replace as much of the copper pipes leading to (about 30 ft) and inside the bathroom with Pex that he can access. He says that it is best to do it now while the walls are open and is best to start new. The copper pipes are 60 years old. Is this excessive or even necessary?
Thanks
While I'm at it. I assume I should avoid the plumber who told me pulling permits will add $500 worth of work to the project. Either you do it correctly to code and pass inspection or it should not be done, right?
Thanks
