I'd tear out all of the old galvanized and switch to copper; replace the valves and the faucet on the sink. I'd also consider putting in a washing machine shutoff that controls both the hot and cold in one quick lever action.
If the joints started to leak with a little movement, they are too weak to leave around. Unscrewing the valve from the pipe may only need a bigger wrench, but then it might just break off.
A little practice with a torch and some scrap pipe and inexpensive fittings will give you enough experience to probably do this all yourself. If you aren't comfortable, since your water will be off while doing it, you might want to consider a plumber.
The key to getting the picture files small enough is to resize them to around 600x400 pixels - most picture software can do it, but it can be hard to find. That's plenty to view on the screen, and gets the file size small enough to upload. I think this is freeware, but a program called IFANVIEW works, too.
