Replacing a Corsyn Crane Toilet
Discussion in 'Toilet Forum discussions' started by Jose, Feb 27, 2010.
  1. Jose
    Jose New Member
    Feb 27, 2010
    Philadelphia, PA
    I need to replace an antique Corsyn Crane toilet that has a top feed(?) to the tank. The old toilet tank leaked badly and replacing the tank would require replacing all the tank's plumbing (valve, ballcock, etc.) as well. From what I've found on-line, doing so would be more expensive than buying a whole new toilet. Problem is, I have no idea if new toilets exist that can replace a Corsyn Crane that has a feed that enters from the rear of the tank (more specifically the rear top left corner of the tank). Do modern toilets exist that can replace a Corsyn Crane?
    FYI, I cannot afford to tear down the wall and break up the floor to install a standard toilet. Long story short, the concrete slab on the floor is ~4" and the concrete on the wall is probably close to 3" if this bathroom is anything like the bathroom we're doing a full gut & remodel on.
  2. jadnashua
    The fill valve on all modern toilets I'm familiar with has the supply enter from below the tank. The thing you need to check out is where the flange is in relation to the wall (called the rough-in). If you are lucky, it might be standard. If you choose a toilet with say a 10" rough-in on a standard 12" one in the floor, this would give you an extra 2" behind the toilet, and maybe give you enough room to run the supply hose to a new tank. So, measure where the flange is (it is measured from the finished wall to the center of the drain - do not include the baseboard trim). Then, you can see what may fit.
    At what height is the supply coming out of the wall? and where in relation to the centerline?
  4. Jose
    Jose New Member
    Feb 27, 2010
    Philadelphia, PA
    The height of the supply line is roughly 36". By "centerline", I assume you mean relative to the center of the drain pipe (where the flange is)? If so, that's roughly 6-1/8". We did luck out in that the flange is 12" from the wall. However, the supply line is not copper but "black pipe" and sticks out roughly 2-1/2" from the wall. If it were copper, I could cut it a little closer to the wall and solder an elbow there to keep it out of the way. My understanding is that doing this with "black pipe" is not possible (or at least not easy). I'd have to cut the "black pipe" and thread the pipe to put an elbow on. Not something I've ever done before...
    I really, really appreciate the advice! If you have anymore, I can certainly use it.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You're doing a full gut and remodel would indicate the wall will be removed where the supply line is. Revamping the supply line location should be a fairly simple task once the wall covering is removed. I'm not sure what kind of pipe you have to work with, but will decent access this is a doable job. Get a Toto Drake and you'll be go to go for many years.
  6. Jose
    Jose New Member
    Feb 27, 2010
    Philadelphia, PA
    Actually no. We're doing a full gut & remodel on one bathroom and an in-place remodel on another bathroom (needs a new shower) on the second floor. We need to bring the bathroom on the third floor into (better) working order. That means replacing the toilet.
    Sorry if I wasn't clear enough.
  7. jadnashua
    Black iron pipe should never be used for water supply. Galvanized was used on older homes, but can have problems as it ages. It's likely that the pipe is screwed into a fitting in the wall. You wouldn't have to break much apart to verify this. You could unscrew it, and replace it with a chromed brass nipple shorter than what you have to place it closer to the wall. This shouldn't be a big deal. It looks like this may be an older plaster wall. Harder to repair, but still not a huge issue. If you cut a big enough piece, you can put some blocking behind it, and patch it back and only have to fill in the cut line. Been there and done that at my mother's 60-year old house with plastered walls.
  8. Jose
    Jose New Member
    Feb 27, 2010
    Philadelphia, PA
    We're not that lucky. We have tile and it's on a bed of concrete nearly 3" thick. To be honest I'm not 100% sure what type of pipe it is, but the closest thing I can compare it to is black iron pipe. I'll see if i can verify what type of metal it is though.
  9. Jose
    Jose New Member
    Feb 27, 2010
    Philadelphia, PA
    Well, it's not black pipe... It's non-magnetic so it's not black pipe, but it probably isn't galvanized pipe either. Thing is, it looked like it was because it was covered in something black. I was thinking it might be brass, but I'm not so sure. I haven't had a chance to remove the black stuff coating the pipe. If I get a chance this evening, I'll try and clean it up an d determine what kind of pipe it is. If not, I'll take a photo and attach it.
  10. jadnashua
    If it is copper or brass, you could solder a fitting onto it and do pretty much anything you want. In fact, if it is copper, if you just cleaned it up, you could put a compression valve on. they make some right-angled ones that are fairly low profile. If the OD is 5/8", then any standard 1/2" shutoff would work.
  11. Jose
    Jose New Member
    Feb 27, 2010
    Philadelphia, PA
    Well, my best guess is that the supply line is brass. It looks too yellow and the walls are a bit too thick to be copper. Given I've only ever dealt with brass shut-off valves, I'm going to have to do some research on how to handle brass pipe (and other fittings).
    If any of you have additional advice I'll certainly take it. But I wanted to thank everyone here for offering their help. So very many thanks!
Similar Threads: Replacing Corsyn
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Wednesday at 8:51 AM
Toilet Forum discussions Toilet running randomly even after replacing flapper Feb 7, 2017
Toilet Forum discussions Replacing Toto Ultimate round bowl, 14" rough in - no knee room Jan 21, 2017
Toilet Forum discussions Replacing the lower seat on a Bio-Bidet Jan 14, 2017
Toilet Forum discussions Trouble replacing valve in minimal clearance skirted toilet Dec 4, 2016
