Replacement for toto gmax fill
Discussion in 'Toilet Forum discussions' started by Realt0r, Aug 24, 2010.
  1. Realt0r
    Realt0r New Member
    Aug 24, 2010
    Hamilton Ontario
    I have a toto one piece 6lpf toilet that has a korky fill valve that isn't working properly. I ordered a new part and they sent me the tsu18a which is supposedly the replacement. I installed it and cannot get the water level to stay below the overflow pipe. I have adjusted it down as low as it can go but it still doesn't work. Is there any other adjustment except for the screw?
  2. Terry
    Aug 17, 2004
  4. jadnashua
    Have you checked your water pressure? If it is exceptionally high, the valve may have trouble turning off. Anything over 80# should have a regulator on it. If you have one, it may be shot and need rebuild or replacement.
Similar Threads: Replacement toto
Toilet Forum discussions Toto CST703 refill valve replacement - no refill tube Mar 13, 2017
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Feb 21, 2017
Toilet Forum discussions Norris toilet replacement with a Toto? Jan 31, 2017
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Toto Flapper replacement Mar 9, 2016
