Removing Compound
Discussion in 'Remodel Forum & Blog' started by shluffer, May 18, 2008.
  1. shluffer
    shluffer Member
    Apr 23, 2008
    A while back I attempted to skin coat a wall with compound. Failure would not describe the result. I have started to sand down the wall, but that is going to take forever and a day. Is there an easy way to remove the compound and start over? The wall behind it is plasterboard.
  2. jadnashua
    If it was the pre-mixed stuff in a big bucket rather than a setting compound, you could try a spray bottle with just some water in it, let it sit for a bit, then see if you can scrape it off.
  4. Marv
    Marv New Member
    May 7, 2008
    Accountant
    Northern Illinois
    Rent a Porter cable drywall sander and vacuum. You wont regret it.
  5. shluffer
    shluffer Member
    Apr 23, 2008
    Thanks for the advice. In the end I used my orbital sander. I was hesitant to do it, but figured I should suck it up and go for it. The wall came out very smooth. I need a couple of touch ups, but other than that I'm good. Insane amount of dust though.
  6. Marv
    Marv New Member
    May 7, 2008
    Accountant
    Northern Illinois
    With the Porter Cable there is no dust and it sands very quickly.
Similar Threads: Removing Compound
Remodel Forum & Blog Removing Ceiling made of drywall, chicken wire, and plaster Nov 28, 2012
Remodel Forum & Blog Tips and Tricks on Removing Top Mount Cast Iron Sink Jul 2, 2012
Remodel Forum & Blog Removing marble tile floor for wood floor Jun 22, 2010
Remodel Forum & Blog Removing veneer? May 20, 2009
Remodel Forum & Blog kitchen redo / removing tile Feb 21, 2009
