Removing Boiler Plug from a Steam Boiler
Discussion in 'Boiler Forum' started by dsorkin, Nov 1, 2010.
  1. dsorkin
    dsorkin New Member
    Jun 2, 2010
    New Jersey
    If I wanted to how would I remove a plug from a 2 1/2 tapping on a steam boiler. It looks like it would require a square drive like for a socket wrench only much bigger. Is there a special tool to do this with?
    I am thinking about redoing the near boiler piping to my boiler next summer. It is a 1979 120,000 BTU Dunkirk. It is working quite well after I replaced all the return piping, installed an electronic LWCO, automatic water feeder, reduced the pressure to 2 psig, and gave it a thorough cleaning. However, in my continuing research I think it was installed incorrectly in the first place resulting in too high steam velocity exiting the boiler (calculated to be around 30 fps). Possibly I will add a second riser or change the the existing riser to one that matches the size of the boiler tapping. (2" vs. 2 1/2"). Any thoughts?
    Thanks
  2. pachai
    pachai New Member
    Jul 25, 2005
    Getting plug out
    Well, it's been a year since this post, and
    now I have the same question, so I am wondering
    how this turned out for you?
    (I'm expecting I just need to wait until the end
    of the season, when I can work on it for a week
    or two :)
    Thanks
  4. dsorkin
    dsorkin New Member
    Jun 2, 2010
    New Jersey
    How I removed it
    I struggled with the plug for a long time. I tried soaking it with penetrating oil over a multiple days, heating the surrounding metal with a torch, banging on it with a hammer, using a very long lever on the wrench - nothing worked. Finally I drilled a big hole in the plug with a step bit and then used a reciprocating saw to cut pie shaped wedges out of the plug. The cuts do not go all the way through so as not to damage the threads on the boiler. Then use a cold chisel and hammer to cut the remaining metal and remove the wedges. When using the saw also be careful not to cut the inside of the boiler. Good luck!
Similar Threads: Removing Boiler
Boiler Forum Problems after removing how water storage tank Feb 27, 2013
Boiler Forum Consequences of removing basement heat exchangers on a FHW system? Dec 23, 2010
Boiler Forum Boiler Purge Design Question/Suggestion Today at 6:43 AM
Boiler Forum Need help understanding and adjusting temp on boiler system pics included Feb 14, 2017
Boiler Forum Triangle tube boiler, ignoring demands for space heating Feb 9, 2017
