Remove a brick? Or drill holes through the brick?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bassadict69, Oct 12, 2010.
  1. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    I am needing to run 2 water lines through my brick wall...should I drill through the brick? Or simply remove a brick and then seal it back up with foam or some other sealant?
    Whichever I should do, what is the best way to do it?
  2. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    I'd drill with a hammer drill and just make the hole as close to the OD pipe you are drilling.
    Seal up the remainder with a good sealant like Sikkens or Sonnerborn sealant.
  4. hj
    Get a hollow core drill bit and you will not "demolish" the other side of the brick when the drill goes through the brick.
  5. Gsalet
    Gsalet George the Plumber
    Sep 19, 2010
    San Francisco
    Remember you want to allow space around the pipe so that the pipe does not wear out prematurely from the vibrations caused by the water flowing through the it. Code say 2 pipe sizes larger, I would suggest at least a 1/4 inch around the pipe. I would also suggest some sort of sleeve even if it is only a couple wraps of 10 mill tape, then caulk it up with some hi quality silicone.
  6. bassadict69
    bassadict69 Member
    Oct 6, 2010
    ER Registered Nurse
    Benton, La
    Thanks guys...
Similar Threads: Remove brick
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Remove/replace/extend closet ring Feb 9, 2017
Plumbing Forum, Professional & DIY Advice How to remove stubborn tank bolt? Nov 26, 2016
