Remote control load switch?
Discussion in 'Electrical Forum discussion & Blog' started by snafflekid, Jul 30, 2007.
  1. snafflekid
    snafflekid Electrical Engineer
    Apr 23, 2007
    Electrical Engineer
    I have a question. I have a swamp cooler which has a two speed fan on it which is wired to a switch that turns it either on high or off. It's load is 11.5 Amps. Is there some kinde of remote control available to switch this big of a load between high and low? I'd prefer to not run a 14/3 cable. Ideas?
  2. HughJazz
    HughJazz New Member
    Jul 2, 2007
    DuPage Co.,IL
    You could use a relay.
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    As I understand the problem, you want to install a remote switch of some kind that will allow you to control the swamp cooler and allow the full OFF-LOW-HIGH-OFF sequence. If that's the case, you've got to install a switch and run a cable of some kind.
    The simplest way by far is to run the 14-3, but you could install a simple pushbutton switch, and run a small wire to pick a stepping relay that would advance one position with each push of the switch.
    Another possible solution is a wireless controller of some kind, a la the X-10 family, or maybe something even fancier these days. Start with Google.
Similar Threads: Remote control
Electrical Forum discussion & Blog Need new remote control kit for Hunter Fan Feb 16, 2014
Electrical Forum discussion & Blog low voltage remote control dimmer Mar 11, 2013
Electrical Forum discussion & Blog Can remote electric meter reading cause circuit breakers to trip? Apr 11, 2011
Electrical Forum discussion & Blog Standard 3W and 4W switches co-existing with master/remote dimmers Dec 7, 2010
Electrical Forum discussion & Blog Remote repeater Oct 14, 2009
