Hi All,
I think this site is great and I'm sure this has been asked a thousand time by now. However, I did search and couldn't find exactly what I was looking for.
I thought I wouldn't have a problem doing this but after research, I'm feeling overwhelmed. I want to move laundry to 2nd floor. I don't have a problem moving water lines, but it is the drain I'm struggling with.
I suppose I think I have a few options.
1. Run all new 2" drain with venting. Or can I tie into other drainage nearby? I assume not.
2. Have washer drain into the laundry sink, would this be easier for some reason? Could this tie into nearby plumbing since it's a sink and not under as much pressure as washer?
3. Run the new drain to the existing washer drain. The existing laundry is on the main floor. Could I run in basement and up to the new 2nd floor laundry?
Lastly, I was going to add a drain in the floor, can I tie that into the same drain or does that have to be separate?
I'm sure I'm missing a lot of info but any feedback would be appreciated. I can do a lot of projects but if this is out of my skill set, I'll hire a plumber.
