Regular Maintenance for Fleck 5600SXT?
Mauser
New Mexico
I am relatively new to water softeners - just replaced a 13 year old Sears cabinet system that I inherited with a 64K Fleck 5600SXT.
The manual for the old Sears unit called for regular cleaning of the screen, nozzle and venturi (and provided an easy access cap to do this). I have not found any such requirements in the Fleck service manual.
Is there any regular maintenance needed or recommended for the Fleck valve?
Bannerman
Ontario, Canada
If your well water has visible sediment, you would probably want a sediment filter prior to the softener.
Assuming your water does not contain iron or manganese, every few years, allow the salt level in the brine tank to become low to facilitate cleaning out debris that has accumulated. At that time, you could also remove, inspect and clean the injector screen as it has easy access, necessitating the removal of only two screws.
With iron bearing water, regeneration with an iron removal cleaner such as Iron-Out or similar would be necessary to dissolve and remove iron deposits which accumulate on the resin beads and valve internals including the injector. The frequency for this manual cleaning process would vary depending on the level of iron reaching the softener.
ditttohead
Water systems designer, R&D
Ontario California
In good clean water, maintenance can be as simple as waiting for the system to stop working 10-20 years later, rebuild, and go for another 1-20 years. It really is dependent on your water supply. Annual sanitizing is cheap and simple and a good practice.
