re: the most reliable shower pressure balancer system.
Discussion in 'Shower & Bathtub Forum & Blog' started by gramps, Nov 4, 2013.
  1. gramps
    gramps Member
    Jan 20, 2009
    Toronto, Ontario
    I am redoing a basement shower and wish to add a pressure balancer. In the basement, the look of the finish is not of primary importance. I just want it to work well.
    Is it better to install one separately to the shower head/handle assembly? or one unit that includes the balancer?
    My concern is that I want a balance that is reliable. Who makes the most reliable pressure balancer or shower system with integrated balancer? Who to stay away from.
    thanks
    -g
  2. gramps
    gramps Member
    Jan 20, 2009
    Toronto, Ontario
    if the fixturs are pricey, is there anything wrong with buying a reasonably priced fixture (moen maybe?), but using a good grohe balancer?, or must both products be the same.
  4. guy48065
    guy48065 Member
    Sep 26, 2013
    SE and north MI
    Can I assume from these answers that there is no such thing as a "stand-alone" balancer that could be installed in the pipes before the shower valve? I would much rather buy a quality device like that and a cheap unbalanced valve than an expensive valve with a cheap plastic balancer built in.
  5. Terry
    Aug 17, 2004
    We haven't had problems with any of the new (if you consider twenty years new) pressure balance valves from Moen, Delta, Kohler, Price Pfister.
  6. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Would thermostatic temperature control shower valve be better than a pressure balancing valve?
  7. gramps
    gramps Member
    Jan 20, 2009
    Toronto, Ontario
    i don't know what that is. why would someone buy this over a pressure balancing system?
  8. Terry
    Aug 17, 2004
    I don't know that there is much difference.
    The Thermostatic can be dialed for temperature, regardless of water heater temp.
    With a non-thermostatic, you may need to turn the dial farther over, or less, depending on the water heater output.
    Either way, they lock in pretty well.
    In the 70's Installed the Moen 2620 single handles for my parents.
    But then I was getting a few complaints when family came to visit. One day I took a shower there, while someone was using the kitchen, and that was enough for me.
    I went back and installed Moen Posi-Temp.
    That being said though, the home I'm in now has Moen 2620 valves, and the expansion tank in the garage helps to even the pressure quite a bit.
    I've noticed in the last two homes, that adding an expansion tank makes a "big" difference in pressure balance issues.
  9. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
    When I remodeled the 2nd bath (about 4 years ago) I installed a Grohe thermostatic valve.
    It's really nice - you can preset the temperature (there's a stop). Just turn on the water - no fiddling, no mixing, the set temp all the time.
    You buy a Grohe rough-in box, then the valve / mixer / diverter that you want.
  10. guy48065
    guy48065 Member
    Sep 26, 2013
    SE and north MI
    No problems meaning no repairs/replacements? I can't claim that...
  11. hj
    When they work, all the systems are effective, but since they are all mechanical devices, they all can fail, but repair or replacement is usually fairly simple.
  12. guy48065
    guy48065 Member
    Sep 26, 2013
    SE and north MI
    OK to answer my own question I did a little Googling and found there ARE in-line pressure balancing valves. Would using one ahead of the shower valve--either just before it or under the floor--allow me to use standard 2-stem shower sets and pass code?
  13. Terry
    Aug 17, 2004
    An inline pressure balancer lets you use a two handle valve.
    If you have a soaking tub, many places want to see a tempering valve to prevent scalding too.
Similar Threads: reliable shower
Shower & Bathtub Forum & Blog Do "L" shaped shower rods make for a reliable shower design - Small, Corner Shower Jul 13, 2013
Shower & Bathtub Forum & Blog Reliable Tub/Drain Overflow Units - Which brands are reliable Jun 15, 2011
Shower & Bathtub Forum & Blog Need help in identifying shower faucet Yesterday at 6:36 PM
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Wednesday at 2:58 PM
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Wednesday at 12:50 PM
