pam h
Hello, I had the old piping to my radiators replaced in my basement as part of a basement finishing project. The old steel pipe was replaced with copper. The old couplings were re-used. (One was replaced because it broke during disassembly.) So the system works fine, heat gets to all 5 radiators. The problem is that some of the unions leak a small amount. Most of the leaks are coming from the coupling union. I've called back the plumber, but I wanted to get some advice. I feel like they will want to go in and replace all the unions - this will undoubtably add quite a bit to the cost. Is it possible to work with the old unions and get them to stop leaking? Is there a compound that can be used on the threads? Thanks for any advice.
