Question regarding the running of high-voltage power cables
Discussion in 'Irrigation / Sprinkler Forum' started by osx-addict, Nov 1, 2008.
  1. osx-addict
    osx-addict Software Engineer
    Jun 29, 2006
    Software Engineer
    Los Angeles
    Hi all..
    I'm guessing I already know the answer to this but thought I'd ask anyway.. I've got some existing 3/4" gray PVC conduit running under a patio that holds some low-voltage (12v) lighting cables and the sprinkler solenoid valve cabling.. I'd like to put a 110v weather-tight outlet in my front yard for Christmas decorations and whatnot.. Originally I was thinking I might be able to run it in the same existing conduit as the 12v + sprinkler cabling but am concerned about the 110v sine-waves causing problems with the sprinklers and the general notion (per code) that you shouldn't mix low-voltage & high-voltage cabling in the same conduit..
    Luckily the run is only 4-5' so I might run opt to run a separate new line for the high-volt cabling. Anyway, does this sound reasonable?
  2. hj
    wires
    As you said, you already knew the answer.
Similar Threads: Question regarding
Irrigation / Sprinkler Forum Stupid questions...regarding wiring.. irrigation Jul 24, 2012
Irrigation / Sprinkler Forum Rainbird 32SA Question Sep 9, 2015
Irrigation / Sprinkler Forum ESP-ME Rain Bird controller question Jun 20, 2015
Irrigation / Sprinkler Forum Backflow and PRV (some questions on correct way, replacement, etc.), winter damage Mar 30, 2015
Irrigation / Sprinkler Forum Questions about Pressure Vacuum Breaker Aug 7, 2014
