Question about proper fittings to use on shower drain
Discussion in 'Shower & Bathtub Forum & Blog' started by MP5SDA3, Dec 26, 2007.
  1. MP5SDA3
    MP5SDA3 New Member
    Dec 26, 2007
    Hello, new to this forum. I am installing a Schluter shower system using a 2" drain. The original drain was 1.5" and between joist bays. Installing the new 2" trap means that I have disconnected the old 2-2-1-1/2" Wye fitting, capped it off and will cut the 2" drain pipe upstream and insert a fitting of some type- either a Combo, or Wye or San-T? Which is code or proper?
    Second question is- it is reasonable to use a short radius 90 degree ell like a vent ell immediately after the shower drain which then connects to the trap, or do I need to use a long turn 90 degree or something else. This is important because I will have to cut into a double 2x10 joist some to get the needed clearance for the drain/trap assembly.
    BTW, the vent system is retained by using a San-T with Street fitting on the vent side which is 1.5" and is VTR.
    Thanks in advance for any assistance!
    http://www.schluter.com/media/ShowerBrochure-ENG07.pdf
    MP5SDA3...
  2. Terry
    Aug 17, 2004
    [​IMG]
    Normally a p-trap for a shower has a very tight street bend into the weir of the trap.
    Most code requires a combo on it's back for venting if horizontal, or if on the vertical, a santee.
    Waste and trap are 2"
    Vents are 1-1/2"
    If the installation is from far enough back, you may notice that the fittings and sizes they used are different.
  4. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    It sounds like you have a sanitary tee on its back laying horizontal, not right a vent must come off a horitontal drain at least 45 or more vertical and you need a wye like Terry said not a tee. A vent cannot run horizontal under the shower.
Similar Threads: Question proper
Shower & Bathtub Forum & Blog Shower pan question Dec 6, 2016
Shower & Bathtub Forum & Blog Shower surround questions Dec 5, 2016
Shower & Bathtub Forum & Blog Tub Overflow Valve Question Oct 24, 2016
Shower & Bathtub Forum & Blog Sterling Ensemble, Basic questions Oct 22, 2016
Shower & Bathtub Forum & Blog Shower Pan Question Sep 28, 2016
