greetings,
i'm a new home owner and i've got a sump pump that has pvc piping going up and out through a hole in the cement wall in an unfinished basement. the pvc pipe that goes through the wall has broken off a bit on the exterior side. outside you can remove the arm joint that connected to the piece that goes through the wall, but the piece that goes through the wall is glued or cemented to the concrete. it's cracked and a small amount of it is missing such that water will squirt down the exterior cement from the arm joint.
how can i remove that cracked pvc pipe? do i just need to fit a smaller pipe inside the cracked one? should i use rubber tubing?
if what i wrote above was unclear i can email a photo. thanks.
-mj voss
-mj voss
