pvc pipe cracked inside a cement wall
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mj voss, Aug 7, 2007.
  1. mj voss
    mj voss New Member
    Aug 7, 2007
    greetings,
    i'm a new home owner and i've got a sump pump that has pvc piping going up and out through a hole in the cement wall in an unfinished basement. the pvc pipe that goes through the wall has broken off a bit on the exterior side. outside you can remove the arm joint that connected to the piece that goes through the wall, but the piece that goes through the wall is glued or cemented to the concrete. it's cracked and a small amount of it is missing such that water will squirt down the exterior cement from the arm joint.
    how can i remove that cracked pvc pipe? do i just need to fit a smaller pipe inside the cracked one? should i use rubber tubing?
    if what i wrote above was unclear i can email a photo. thanks.
    -mj voss
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    cracked pipe
    if it is 2 inch you could probably get away with
    an 1 1/2 pipe going through it
    if it is 1/1/2 I suppose you could run an 1 1/4 pvc pipe
    through it too.....
    we sitll run into 1 1/4 lines fo rsump pumps...so it probably
    wold get you out of troubles of getting that pipe out of the wall
  4. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Idea...
    Caulk the outside diameter if the exterior portion with silicone...insert, the silicone should both seal and hold it in place.
    The right thing to do....chisle out the adhesive inside...work the pipe out and replace it.
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Why not run a "ram bit" through the hole...
    It will chew the pipe out of the hole and allow you to push a new one through....
    Did that at one of the jobs I am at...
    Used a 12" extension and a bit of time but was successful in boring some 3" PVC out of a 10" thick wall that some idiot (insert concrete worker's name here) had snapped off flush while operating a backhoe...
  6. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Beats the heck outta my idea on chiseling adhesive, but wouldn't that chew up the rambit with the surrounding concrete?
  7. markts30
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Didn't hurt the bit - the bit itself is the size of the pipe - Concrete was smooth so it just acted like one long fitting hub....
  8. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    I don't know what a Ram-bit is but if I had to do it I would cut both ends off flush and apply heat (torch or heat gun) to the PVC. PVC will soften and you should be able to collapse it into the hole to remove and replace it.
    You could also run a hacksaw blade or a SawZall through inside the pipe to cut it. Use a junk blade that the concrete will not ruin and work from both sides if necessary. As I write this, I think I would start with the SawZall rather than the heat. Two cuts along the pipe should let you knock it loose and out.
    If you use the same size pipe you will have to clean out the hole a bit as you have "zero clearance" from pouring the concrete around the original pipe.
    Seal around the new pipe with silicone.
  9. markts30
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Here is the manufacturer's catalog with the rambit in it...
    Gives a good pic or 2 of it in action....
    They work really well and have saved me lots of time and the company a good bit of money in the past...
    http://pascospecialty.com/catalog/PASCO_CATALOG_C.pdf
Similar Threads: pipe cracked
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cracked drain pipe under shower concrete slab Sep 4, 2015
Plumbing Forum, Professional & DIY Advice Repair Cracked Drain Pipe in Slab? Nov 10, 2010
Plumbing Forum, Professional & DIY Advice Cracked pipe in wall May 31, 2009
Plumbing Forum, Professional & DIY Advice Question on bill to repair cracked pipe May 18, 2009
