Tim Meneely
Will a joint fit more loosely (deeper) with solvent than it does dry?
I'm using a Sioux Chief 884-PTM TKO closet flange (new, PVC, solvent weld) inside a 4-inch PVC pipe (Charlotte pipe, new). The flange readily slips about 1/2 inch into the pipe, but then it starts to stick. Using what I think is reasonable force I can dry fit it about 2 inches, which is still a half inch or so from bottoming out. To dry fit it the rest of the way would require a hammer or something.
I have three questions:
I haven't glued anything yet so have all the freedom in the world.
Thank you,
Tim
- Is the flange supposed to bottom out inside the pipe?
- Will the two fit more readily when I have primer and solvent on them? (I think they will, but counting on that is scary - what if they don't?)
- Should I do something to prep the two to make them slide together, for example use a little sandpaper? (This seems like a bad idea).
Thank you,
Tim
