a little background.. My pump was turning on and off every 12 minutes so I figured the foot valve was leaking (I replace every few years). So I pulled the lines from well and replaced connector and foot valve, the galvanized connection is actually what rusts and leaks not foot valve but I replace while its out.
So I decided I'd change my pressure tank while I was at it because it was old and actually undersized so I bought a larger one. When all back together I knew I would need to go under the house and prime my pump again, once I got it primed and pumping it won't build past 34 psi suddenly (it was prior to these repairs). So I have to back my switch off to accommodate so what is my problem?
