Pump won't pump to pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by DeeJay, Nov 23, 2010.
  1. DeeJay
    DeeJay New Member
    Nov 16, 2010
    Glen Williams Ontario
    The plumber is downstairs right now.
    He brought the new 1/2 pump mounted to the new 19 gallon bladder tank and hooked it up this morning.
    Apart from a couple of minor leaks (he just is changing the plastic fittings to metal) the darn pressure won't go above 15 lb (preset to 20-40).
    Lots of well water, new well line 25 feet to the well. We have no check valve in the feed line from the well, but it's so close and the well is only 5 feet deep.........We checked and reset the tank bladder to the recommended 18 lb pressure.
    Blew the air out at all the taps, but even after, closing a valve so that it doesn't run into the house, the pressure mainly sits about 10-12 lbs. With the other system, if I closed that valve, the pressure would shoot to 60 lb in a sec or two.
    Any suggestions???
    Maybe these new fittings will make a difference, but I'm skeptical.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You need a check valve or you can't get the pump primed. Also could be a hole in the suction pipe or the jet is clogged up.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    As valveman said, if your pump doesn't have, you will need a check valve in suction line. If it won't build pressure it tells me that either there isn't a jet assembly in or on the pump. If there is, the nozzle in the injector (jet assembly) is plugged or partially pluggeg with debris. You will have to remove the venturi then the nozzle, clean the nozzle (it will have a 1/4" hole in it).
    Pumps don't build the pressure, the injector (jet assembly) builds the pressure.
  5. DeeJay
    DeeJay New Member
    Nov 16, 2010
    Porky, you were dead on!! When the plumber came Thursday to look at the old set up, I gave him the new pump in the box to take back to the shop. He could then get the necessary fittings etc.. The following Monday he came back, took out the old pump, and I gave him the new bladder tank to take back to the shop for the next day's install.
    Tuesday he came with it all prefitted... but as described it made only 12 lb pressure.
    After several attempts to modify things, and stop a couple minor leaks, I picked up the box and saw a picture saying it needed a shallow well kit for under 20' wells. He hadn't noticed it!
    Because the pump was US purchased through Sears, I couldn't get a shallow well kit for it in Canada, though I spoke twice to the manufacturer in Wisconsin. I called the friend in Detroit who gave it to me, and he found the international ordering link for me. I ordered the kit last Thursday, and it's to be shipped in the next 10 days. About $75 shipped.
    Hopefully the connections made without the kit will not have damaged anything on the pump. The 'plumber' the reno company sent is not a real plumber, I suspect...more of a general knowledge guy. He'll have to re-work a few connections, but it should be a piece of cake once the kit arrives.
    Though I know I'll still be billed for a half day of wasted efforts on his part!
    Thank for the feedback!
  6. ballvalve
    Dec 28, 2009
    northfork, california
    Don't call plumbers for pump and well work.
  7. Gary Slusser
    Retired
    Learn to DIY.
  8. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    And don't buy water pumps from Sears. Next time find a Goulds
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
    Sears is just another name for Sta-Rite, Meyers, Pentair, etc. I think they are just as good as Goulds.
  10. DeeJay
    DeeJay New Member
    Nov 16, 2010
    I can't really comment, except to say that the pump that I took out is a Sears 3/4 hp, and it's run perfectly for 30 years. The only maintenance has been getting the motor bearing replaced twice, when it starts to get a little loud. It was still working fine when it was removed last week, and then only because I had a new Craftsman pump sitting there in the box.
    I plan to run a line into the lake, and use the old Sears pump for watering the lawn and flower beds, building a box outside for it, and using the old galvanized tank.
    If I get 20 years from this new pump (it is a seasonal home) it won't owe me anything.
Similar Threads: Pump won't
Pumps and Tanks Well Forum & Blog. Water is life. Well pump pressure switch won't engage Mar 18, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Generator won't run well pump Jan 31, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help! Submersible well pump runs but won't build pressure over 30 psi! Nov 13, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well pump won't build up pressure Aug 23, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Water pump won't maintain pressure Feb 4, 2015
