Pump options for shallow well?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Now you are talking. Knowhow and the right equipment for the job makes a lot of difference. If I were having a problem I would call Boycedrilling. I'll bet you even have elevators. :)
Boycedrilling
Royal City, WA
Yeah, I do. It wears my arms out to screw hoisting plugs in and out of the drop pipe. And if you've ever had the lifting plug unscrew while you were tightening the joint at ground level, you change too.
I also use the tekmark internal casing elevator on steel well casing. No welding ears on steel casing for me.
Any thing that makes the job easier, safer,and faster, I'm all for.
Boycedrilling
Royal City, WA
Replaced a 2 hp sub pump yesterday. Set 380 feet deep on 1 1/4" schedule 120 PVC. 45 minutes to pull, the same to install the new pump. That's also why I charge by the foot and not by the hour.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yeah the worst is when the bell up top didn't look like it came unscrewed but was just holding by one thread. When you lift the string and pull the plate, the whole thing would go south in a New York minute. It is also amazing how that wire unspooling and flying down the hole would try to grab you, a pipe wrench, or anything laying around and take it down the hole as well.
But you also have to watch the helper when laying down pipe with an elevator. If he didn't make sure the closing plate was on top, it would drop that end of the pipe on top of the operator (me). Fired several helpers for that over the years after a second or third chance. Luckily I never got injured like that but I did have to clean out my undies several times. Wish I had a nickel for every time I had to tell my helper to spin that pipe the other way.
BJ oil field elevators and slips are the safest. But if you bounce that string on those slips they would fly up and open, and those were not shallow wells to be fishing in. Takes all day to run a string 1400' before you even touch the fish.
Boycedrilling
Royal City, WA
Yeah I have a friend that had a piece of 8" or 10" column, tube & shaft fall on him. It was doubtful for a year or so whether he would ever be able to come back to work. I much prefer the oil field elevators. I have them for bottleneck drill pipe and for a 1600 ft string of 2 3/8" upset tubing I use for cementing. Elevators aren't idiot proof either. I'm breaking in a new helper. That's one of the first things I teach, is proper direction of elevators.
Most domestic wells, I use the Baker L shaped elevator. They're rated for 6-8000 lbs load which is enough to for most domestic work. I use the Baker clamp in conjunction with their elevator.
