Pump only runs when I push the contacts together
Nate Clinch
Maine
Started having this issue first thing this morning no water pressure. Went down checked pumped fuse wasn't popped or anything. But it won't run I took the cover off and closed the contacts and it ran fine but shuts off a soon as I release.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The little nipple your pressure switch attaches to is probably clogged up. If the points in the switch won't close or stay closed at low pressure, either the switch is bad or there is enough pressure in the nipple to make it think the system is full.
Nate Clinch
Maine
That was it it was frozen I warmed with my hands and it kicked right back on thank you !
