Pump holds prime but pressure drops to zero when starting
Discussion in 'Irrigation / Sprinkler Forum' started by kegobeer, Jun 22, 2011.
  1. kegobeer
    kegobeer New Member
    Jun 22, 2011
    Panama City Beach, FL
    I had a leaky check valve that caused my pump to cycle rapidly. Once I replaced it, a new problem started. After I primed the pump, it shut off and held pressure at 60psi. I opened a valve, and the pump kicked in around 40psi (I have a 40-60 switch), but almost immediately after that the pressure dropped to zero. I can reprime the pump, and sometimes when the pressure drops it can recover and then run through all the zones perfectly (no pressure drops when it goes from zone to zone), but most often the pump can't recover and I have to shut it off and reprime.
    I hope someone can help me track down this problem. Thanks in advance!
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Busted bladder, too much precharge, or waterlogged tank.
  4. kegobeer
    kegobeer New Member
    Jun 22, 2011
    Turns out my brand new check valve was bad. The reason the pressure was dropping to zero was because the valve wouldn't open when the pump turned on. Replaced it with another new one and I no longer have a pressure drop when the pump turns on.
Similar Threads: Pump holds
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Shallow well pump issues Sep 24, 2016
Irrigation / Sprinkler Forum Simple garden hose sprinkler on Well pump issue Jun 25, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
Irrigation / Sprinkler Forum Timer for irrigation pump? May 13, 2016
