Hi,
I have a new 1hp shallow well jet pump, new pressure switch, new check valve.
When the pump is primed it reaches 50psi and switches off. However, in each of the first two hours, it loses about 8 psi and then about 2psi per hour. Once the zones are run and finished it loses all 50psi within 3 hours?? There are no visible leaks.
