Pump cutting off
Billelliott1964
Pass Christian MS
Run water switch closes at right pressure pump kicks on runs for about 30secs, then stops, pressure never fully restores, changed pressure switch same issue have full 230volts across switch. It's a vertical star lite 2hp pump
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yes the motor is thermally protected. It has an auto-reset overload that resets itself after a minute or so. That is when you hear the click and the pump tried to start. Typical pump failure. The pump cycles on/off for a few years with the old pressure tank system. Once you have used up all the on/off cycles, the overload starts to trip. You can try a new control box, but most likely you will need a new pump/motor. And if you don't want history to repeat itself, figure out how to stop the pump from cycling and it will last much longer.
Texas Wellman
SE Texas-Coastal
Sounds like you have a 2hp sta rite jet pump. A rare item and expensive. Model msg?
From your description the motor is not coming up to full speed. After a little while running slow it trips the overload. These motors have both a start and run capacitor. Try checking these. Also check the centrifugal switch and governor under the top cover. Look for anything burned.
