sdoucette
I have an outdoor well that feeds my irrigations and a few outdoor spigots. The problem i am having is recently i've blown 3 pressure switches in a matter of a couple of months. I'm under the impression this is due to over cycleling. Unfortunately when I replace the switch i run the pump and the system and it seems to be fine, until the next morning i wake up and the switch is fried again. I have a few thoughts and would like some opinions on them: By the way i have a jet pump shallow well with a very small pressure tank
1) the check valve between the pump and the well is gone.
2) the pressure tank is too small or bad (pressure is consistant). worked fine for 7 years.
3) leak somewhere in the irrigation - would have to be small since I don't see any loss in pressure when watching the gauge
4) pump is no able to keep the pressure about 40psi while running causing the switch to kick on even though already running (is this even possible)
Before I replace the switch again, buy a bigger tank, replace the check valve and solenoids on the irrigation valves, I would like to know what you folks think. I have the ability to do most if not all of this myself, I just don't know where to start.
