Proper setup for double sink plumbing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by samohtep, Mar 27, 2014.
  1. samohtep
    samohtep New Member
    Mar 27, 2014
    Hamburg, NY
    Hi All,
    I thought this would just be a quick and easy job, but the more I look into it, the less I know how I should do this. I want to remove the garbage disposal from my kitchen sink. I posted a picture to another forum asking whether I needed p-traps on both drains. The current setup is a two bowl sink, garbage disposal on the left drain, and dishwasher hose connected to the disposal. There's a P-Trap from the disposal to the drain from the right bowl, then a goofy looped S-Trap where the outlet drops through the floor to the cleanout in the basement. The house is 90 years old and while the pipes aren't, they seem to have been pretty cobbled together over the years.
    The first response said 2 traps weren't needed, the second response but said I needed a vent.
    The second response confirmed 1 trap and vent, then explained the S-trap at the floor line.
    I called the town code enforcement office today and he advised me to check the New York State code.
    Also, I contacted a local plumber about the work, including a photo and here's the response:
    "It sounds like you r not having any problems with draining or venting
    **s-traps are ok to use and we still sell them. *If you are *remolding *them you might want to replum in pvc pipe with proper venting ."
    Sooo, yeah, I don't think I'll be trusting them to do it…
    Anyway, I saw this link:
    http://www.hammerzone.com/archives/kitchen/sink/drain/02/replace_old.htm
    The difficult bit that I keep coming back too is that the drop through the floor is only offset an inch or so from being directly beneath the right bowl. If it helps, I'll post a few better photos when I get home. Any suggestions would be greatly appreciated.
    Thanks
  2. hj
    The disposer does NOT need that trap, but the "S" trap has to go. In order to reconnect the sink without the disposer, (NOT a "Disposal"), you need a continuous waste horizontal pipe, a flanged tailpiece out of the new sink drain fitting, and a dishwasher connection tailpiece between the strainer's tailpiece and the waste pipe.
  4. Terry
    Aug 17, 2004
    I would like to see the disposer plumbed to a tee below the right sink. Also an AAV on the line coming up from the floor.
    If you need to offset on the vertical, that's fine.
    The dishwasher line should be strapped as high as you can in the cabinet before it enters the disposer, or install with an air-gap.
    The rest of the country quit doing S-traps decades ago. If I were New York, I wouldn't be bragging.
    And, it hurts my eyes looking at the handyman work on hammerzone.
    [​IMG]
  5. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Yeah, the NYC metro area doesn't seem to worry much about air gaps or high-loops on the dishwasher installs. In fact, when we had one installed recently, I suggested an air gap.
    "A what?"
    Great. They did know what a high loop was, but insisted it wasn't required. Swell. Do it anyway.
    I know for a fact, however, that an S-trap isn't going to be permitted.
  6. yngwie_69
    yngwie_69 New Member
    Sep 8, 2009
    Prince Rupert, BC
    Cleanout
    If thats a galvanized tee cleanout, your doomed for constant plugging up.
  7. hj
    he indicated that he was removing the disposer. That is a cast iron "drainage" tee, which was the required fitting when it was installed.
  8. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    Thank you Terry for mentioning the Hammerzone link. Of course now I had to check it out. I share your horror! I can never "unsee" that incredibly bad work being passed off as the right way plumb. "Hammerzone" makes me want to hammer my head trying to get the images out of my mind! Even worse is the comments on the page are generally positive and thankful for the "good advise." It is a shame anyone with internet access can post really bad information as fact and mislead thousands of poor souls who just want help. Now back to the current thread...
  9. samohtep
    samohtep New Member
    Mar 27, 2014
    Hamburg, NY
    Thanks all, I had seen the link for the Hammerzone page in a thread here, so thanks for the correction.
    Based on the comments, I put this together. (Grey existing, Red new)
    Is it completely insane? As I mentioned, the drop through the floor, is almost directly below the right basin, maybe an inch closer the the face of the cabinet and an inch to the right. Any corrections?
  10. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    That would be a proper installation.
  11. Terry
    Aug 17, 2004
    I like it too.
    and the drawing is amazing. :)
  12. samohtep
    samohtep New Member
    Mar 27, 2014
    Hamburg, NY
    Awesome, thanks for the help.
Similar Threads: Proper setup
Plumbing Forum, Professional & DIY Advice Proper Drain / vent setup for Dish Washer Mar 6, 2009
Plumbing Forum, Professional & DIY Advice Proper drain slope on short run Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Proper material for outdoor risers and manifold Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Is this vented properly? Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Proper replacement for a disintegrated copper cleanout seal? Sep 8, 2016
