Procedures for "T" Key to dislodge from well pitless adapter - help!
SergioMastro
Guys,
I have a few questions on how to pull well pump our of well. I do have a pitless adapter and need procedures on how to pull out pump.
Here goes:
1. What is this "T" key tool called? Any pictures of this tool, so I can get a visual feel?
2. Where is it sold? What are aprx costs for this tool?
3. What are the procedures to use this "T" key on pitless adapter?
4. Once dislodged, what is being pulled up? wire + blue line?
Thanks in advance?
Sergio
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
All you need is a piece of 1" steel pipe, long enough to reach the pitless, with threads on both ends. On the top end you thread on a 1" tee, with 2 nipples sticking out the sides for a handle. The 1" threads on the bottom should screw right into the pitless half.
When you pull the pitless half up from the stationary part, you are lifting the pipe, wire, pump, and everything at the same time. Just don't let anything hang up on the stationary part of the pitless as you pull it out of the well.
Some pitless units have a cable release. If you don't see a cable, it should just pull straight up and out.
Southern Man
DIY Hillbilly
North Carolina
You can also buy a shorter length of 1-1/2" steel pipe and slide it over the 1" pipe prior to assembling the Tee handle. You can then use the larger pipe as a slide hammer to help break free the separate parts of the pitless adapter.
