problem with shower
Discussion in 'Shower & Bathtub Forum & Blog' started by jakesdaddy, Feb 21, 2005.
  1. jakesdaddy
    jakesdaddy New Member
    Feb 21, 2005
    I have a 3 stem type setup on my tub. I think it's a Price Pfister...
    One stem for hot; one for cold; and a shower diverter.
    However, when I turn on the diverter, hardly any water comes thru the shower head. Is there a special way to adjust the diverter after taking it off?
    Would replacing the diverter fix the problem? Any help is appreciated.
  2. jimbo
    jimbo Plumber
    First thing to suspect is the shower head itself. Remove it, then turn on the water. It should be a gusher. If not, then remove the diverter stem and see if some debris is inside. On that PP, you will often find broken pieces of the old nylon diverter washer.
  4. jakesdaddy
    Feb 21, 2005
    thanks for responding. First thing I checked was the shower head. It's fine.
    I took out the diverter and even redid the washer seat thing-a-ma-bob.
    I have a feeling that the diverter stem itself was/is in an incorrect position.
    After I take it off, should I turn it all the way to left effectively "opening it up" or all the way to the right which would put the stem into a closed position against the incoming water valve. ??
  5. jimbo
    jimbo Plumber
    To reinstall open it up. You do not want the stem to bottom out against the seat as you tighten it into the body.
  6. jakesdaddy
    Feb 21, 2005
    I will try that tomorrow.
    Kinda late to be banging around in the bathroom right now. :)
    My wife would hate that, I'm sure. I will let you know how it goes. THANKS!!
  7. jakesdaddy
    Feb 21, 2005
    That suggestion partially worked. I get water spraying thru the shower head, but ALOT of water coming out the faucet as well. Could the hot & cold stems be adjusted incorrectly? Would taking them off and reinstalling them the way I did the shower diverter help the situation? Could I have the wrong seat size in the shower valve or even the wrong seat in the hot & cold valves? Argh.
Similar Threads: problem shower
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Shower Pressure Problem Jan 21, 2017
Shower & Bathtub Forum & Blog Is there a problem with this bath/shower installation? Mar 21, 2016
Shower & Bathtub Forum & Blog Hot water in shower problem Feb 29, 2016
Shower & Bathtub Forum & Blog Symmons Shower Problems Jan 26, 2016
