problem with ph neutralizer
Discussion in 'Water Softener Forum, Questions and Answers' started by tfasbind, Sep 2, 2010.
  1. tfasbind
    tfasbind New Member
    Aug 31, 2010
    nevada city, ca
    I've been having a problem with (what appears to be) calcite particles appearing in my toilet tanks and bathtub. I have an upflow ph neutralizer system.
    First I installed a reusable sediment filter on the house side of the ph neutralizer, but it clogs up too frequently.
    I talked with a local filter guy that told me that my ph tank head probably didn't have a filter on it (which it didn,t) so he recomended replacing the head with a one which incorperates a filter (which I did).
    Now, whenever we fill the bathtub, it clogs up the ph tank head filter and reduces flow to a trickle. Even if I fill the tub up slowly I still get some sediment in the sediment filter down line from the ph tank.
    My regulater is set at 40-60 and tank at 38. I have the calcite top level at 16" from top of 10x54 tank.
    Would a downflow system take care of this problem?
    I talked to an online supplier who suggested using a Fleck 2510 sxt on a 10x54 tank calcite only.
    Would this system be adequate?
    I have a 1" supply which feeds the main house (3 to 4 people 2 1/2 baths) and a cottage (1 person 1 bath). The pressure tank is fed from a 1500 gal. holding tank with a 20 gpm pump.
    Well recently tested at ph-6.5, iron-0,mag -0.041, cloride -100, hardness -4,alk -4, tds -55 .
    Also, the tank is located in the well house which is outdoors and no convenient drain.
    Since I'm only adding calcite to the water, can I drain to the ground?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Did you just add some calcite to the tank?
    Even with the up flow there the need of space between the media and the top of the tank.
    Even if there is an upper basket to much media is still to much media.
  4. tfasbind
    tfasbind New Member
    Aug 31, 2010
    nevada city, ca
    I did just clean the tank and refill with gravel and calcite when I changed the head to one with a filter. The current media level is @ 18" from the top of the tank ( which should be well within the proper range of a 10 x 54 tank ). That level is down over an inch in @ a week.
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    Level sounds good.
    When the valve went back on did the distributor go into the center hole of the valve? is that O ring in that hole good?
    Did the distributor get cracked ? that could be a challenge in that the water coming out to high and then mixing it up just under the media level and not at the bottom where the gravel is at..
  6. tfasbind
    tfasbind New Member
    Aug 31, 2010
    nevada city, ca
    Can you think of any way to check that without taking the head off? I'm afraid if I take the head off it will pull the distributor lower filter out of the gravel bed and I don't want to remove all of the media and refill if I don't have to.
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    What valve did you use?
    Might you have a photo?
  8. tfasbind
    tfasbind New Member
    Aug 31, 2010
    nevada city, ca
    I bought it from a local water treatment supplier. Basically, it's a cast aluminun valve with an integrated filter. The filter is cone shaped with a hole at the bottom which alows the distributer tube to be installed. The whole assembly is attached to a 3/4" Fleck bypass valve.
    I will post pictures when I get a chance.
  9. Akpsdvan
    Dec 29, 2009
    Alaska
    Sounds like a 2nd tank adapter for the 9000 , if you can use the fleck bypass valve..
    If you unhook the bypass there are only to ways from the out side to the inside of the tank,, one through the hole that looks like it goes straight in and then the other that looks to off to the side.. now the one in the center if you had a dental mirror you might be able to check with a light to see if you see the distributor up in the hole..
  10. tfasbind
    tfasbind New Member
    Aug 31, 2010
    nevada city, ca
    I checked out the 9000 online and the valve that I installed does look a lot like the 2nd tank adapter.
    If I get a chance tomorrow I'll disconnect the tank from the bypass valve and see if I can look in the holes.
  11. Akpsdvan
    Dec 29, 2009
    Alaska
    Another step on the way of figuring out what is going on with the calcite getting in to the house.
Similar Threads: problem neutralizer
Water Softener Forum, Questions and Answers Neutralizer not raising ph: rebed? control problem? Nov 20, 2015
Water Softener Forum, Questions and Answers Problem with neutralizer backwash cycle causing water overflow and spillage Jan 25, 2013
Water Softener Forum, Questions and Answers Trouble shoot problem flex 5600 sxt Mar 15, 2017
Water Softener Forum, Questions and Answers Fleck 9100 SXT valve problems returned 60 days after replacing seals Feb 2, 2017
Water Softener Forum, Questions and Answers Kenmore intellisoft 350 problem Jan 15, 2017
