Pressure Tank Advice
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by davrollins, Jun 30, 2007.
  1. davrollins
    davrollins New Member
    Jun 30, 2007
    Lovely Frederick, MD
    I'm in need of a new pressure tank and am looking for some advice. The first question I have is whether this is a task I should try myself. I'm pretty handy and have worked with plumbing before. Also, the house is about 10 years old, so the piping isn't all the old. The current tank is connected to a brass fitting and then coupled into PVC piping.
    The second question is I've noticed a lot of different brands out there. I typically believe in the you get what you pay for philosophy and notice there could be as much as a $50 difference between brands of the same size tanks. I currently have a Con-Aire and the models I can find in my area are Flotech, WellSaver and Simer.
    Any advice would be greatly appreciated.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I would stay away from all the brands you mentioned. The ConAire you have is the big brother to the Flotec. I have no idea who makes Simer's tank, but they are an offshoot of Red Jacket who is owned by ITT and they don't make tanks, so it's anybodys guess what the real brand name is.
    Stick with Flexcon or Well-X-Trol. Take a look at the CSV's also. You can save money and protect your pump while having constant pressure.
    bob...
  4. davrollins
    Jun 30, 2007
    Thanks, Bob. I did find a plumbing supply store in the area that carries the Flexcon line, so I'll see what they have.
    As far as the installation goes, if I get a tank with the same diameter pipe as the old one, how difficult a process is it to chnage out?
    Thanks again.
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    It's not that hard to do.
    bob...
  6. ktot
    ktot New Member
    Sep 29, 2009
    what's wanted here
    What are CSVs?
    This (quoted below) is an old post, from 2005, but I have two questions.
    1. What is CSVs (I tried googling it but found nothing likely)?
    2. Do the recommendations still stand, to stay away from ConAire, etc., go with Flexcon and Well-X-Trol? And, please, why those recommendations, non-recommendations?
  7. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
Similar Threads: Pressure Tank
Pumps and Tanks Well Forum & Blog. Water is life. Well pressure tank help. Sunday at 3:44 PM
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Feb 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
