RickyJ
Hello All! I’m new to the site and look forward to some expertise advice.
My well air pressure tank is acting a little weird. No water at any outlet. I killed the power to the pump, opened up a few faucets to let water drain. I drained the air tank then added the recommended air pressure into the tank at the schrader valve on top. I filled it to 30 psi but the gauge at the bottom of the tank reads a little under 10 psi. After closing the faucets and turning the power to the well back on I still have no water. I hope I’ve gave enough info to get some helpful advice.
Thanks in advance!
P.S. The home was built in ‘98. I’ve been in it for 4 years so I’m not sure how old the pressure tank may be. I’m sure there’s a date on it somewhere.
Thanks in advance!
