Pressure Switch Range Wont' Adjust
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jacob542, May 26, 2013.
  1. jacob542
    jacob542 New Member
    May 26, 2013
    Florida
    We recently bought our home and have been having issues with the well. The water softener and pressure tank were just replaced. When I was shopping for a pressure tank I realized that my cutoff pressure of 70psi was high. After further investigation I noticed the pressure cut on was at about 58psi. I attempted to adjust the pressure switch but I was unable to reduce the cut-on pressure to 30/50 psi as recommended by the pump manufacturer. The pressure switch started chattering and the cut-on pressure limited out at 45psi. Even after increasing the cut-on pressure I continued to have problems with the pressure switch chattering so today I replace the switch. Same problem! The brand new 30/50 switch is operating at 58/70! I checked the pilot tube from the pressure switch to the discharge side of the pump, clean and clear... If anyone has an idea to get control of my pressure I would be very grateful. This has been a huge headache and after a couple of hours of searching these threads I couldn't find a similar situation. Thanks!
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Maybe your pressure gauge is reading wrong. Compare it to what you read on the bladder.
  4. jacob542
    jacob542 New Member
    May 26, 2013
    Florida
    Sorry, I forgot to mention the gauge was just replaced with the water softener and pressure tank. The pressure tank is set at 28 psi and I want to drop the cut-on pressure to 30psi but the pump isn't responding much to pressure switch adjustments.
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Does the pressure switch have two springs and two adjusters? If so, the small one adjusts only the high side and the big one adjusts the low and to some degree, the high. Where is it mounted, on a tank Tee?
  6. AndrewNYC
    AndrewNYC New Member
    May 26, 2013
    Staten Island NYC
    get a new one
Similar Threads: Pressure Switch
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch question Friday at 8:33 AM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch not providing true short Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Is a pressure switch needed for this gravity fed system? Dec 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch nipple length?? Nov 11, 2016
