pressure reducing valve
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by duffers, Dec 26, 2007.
  1. duffers
    duffers New Member
    Has anyone had any experience with putting in a pressure reducing valve? My water pressure in my home is 105 psi. From what i understand 30-40 is about normal? does it need to be on a horizontal pipe or can i put it on a vertical? How long do they last? What happens when they break? do they leak or does it just increase the pressure back to 105?
  2. jimbo
    jimbo Plumber
    8,997
    A valve will have instructions on it, but I think any model can be installed on a vertical pipe.
    When they fail, it usually involves leak by, meaning the pressure on the house creeps up to full street pressure; or they get "stuck" such that when you turn on a tap, the pressure drops. They don't "leak" if you mean a puddle on the floor! They can last anywhere from 5 to 20 years. A lot depends on your local water quality. Water with grit or sand, or high mineral content, will shorten life. The valves will cost in the range of $35 to $85.
    Residential PRV often are preset at the factory at 55 PSI. In general, the adjustable range is 25 to 75. The normal, or user-friendly , range, is condsidered to be in that 50 to 65 range.
  3. construct30
    construct30 New Member
    590
    NorthWest PA
    I did have an old one leak around the adjustment, but just a drip drip. It's like jimbo said.
  4. mold-griz
    mold-griz New Member
    9
    you can install a pressure reducing valve either verticle, or horizontal. it would be a good idea to buy a pressure gauge, that you can thread onto your laundry tub faucet, and turn the water on overnite, and check to see what your water pressure really is, so you can adjust your regulator to any pressure you want. i was under the impression, that good water pressure should be around 50-60.....
Similar Threads: pressure reducing
Plumbing Forum, Professional & DIY Advice, Tips & Water Main Pressure Reducing Valve Clarification Please Mar 21, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Water Pressure Reducing Regulators Mar 17, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Adjusting Water Pressure on a pressure reducing valve. PRV Mar 8, 2014
Plumbing Forum, Professional & DIY Advice, Tips & pressure reducing valve Nov 5, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Supply to Boiler and pressure reducing valve question Jun 27, 2013
