Pressure Balance Unit in Shower
Discussion in 'Shower & Bathtub Forum & Blog' started by jdserb, Feb 19, 2008.
  1. jdserb
    jdserb New Member
    Feb 16, 2008
    I have a single lever handle shower, just had a new pressure balance unit installed. The lever wasn't put back correctly, and when the shower is turned off, it goes way past the "Off", and when turned to "Cold", it is now warm and when turned to "Hot" it is scalding. However, the problem is the shower will be cool, then a blast of hot will mix in for a second, and this will go on like this the entire time. Does this have anything to do with the lever being put back incorrectly, or can it be a faulty pressure balance unit. The mixing of hot and cold are just not working at all. Please advise
    Thanks,
    jdserb
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Call back the contractor that supplied and installed it to correct the problem.
  4. hj
    delta
    The "rotation/temperature" limiting stop was not replaced when the handle was installed. Without it, the operation is erratic.
Similar Threads: Pressure Balance
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Grohe 35015000 Universal Pressure Balance Rough-In valve Feb 10, 2015
Shower & Bathtub Forum & Blog Riobel pressure balance Shower Valve May 30, 2014
Shower & Bathtub Forum & Blog re: the most reliable shower pressure balancer system. Nov 4, 2013
Shower & Bathtub Forum & Blog Pressure Balancer problem May 28, 2013
