Popup drain leaked on first test
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Elijahwww, Jan 25, 2014.
  1. Elijahwww
    Elijahwww New Member
    Jan 25, 2014
    MA
    I installed a set of Danze faucets in my new bathroom vanity, but the metal drain is leaking on both sinks. It is leaking from either the tailpipe where it is threaded into drain collar or from the collar itself, I can not tell.
    The collar came with rubber washer on top and bottom, so i did not use silicone or putty.
    For the tailpipe I used about a foot of teflon tape.
    The picture below doesn't show the top rubber gasket that goes under the flange, but the unit came with it.
    What did I do wrong?
    http://www.danze.com/file.aspx?DocumentId=299
  2. ImOld
    ImOld New Member
    Jun 1, 2013
    In the rumble seat
    I don't see anything about
    in the instructions.
    Is that a good enough hint for you? :)
  4. hj
    If you used that much tape, I don't know how you even got the thread to start much less tighten up.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Some plumbers putty on the threads before you tighten the tailpiece should do the trick.
  6. Terry
    Aug 17, 2004
    Either pipe dope or plumbers putting on the threads of the drain collar. None on the rubber donut below the sink.
    The tail piece either gets pipe dope or a little tape.
    I have never seen instructions with faucets mention this, but it keeps us employed.
  7. Elijahwww
    Jan 25, 2014
    MA
    Thank you all. I will try the putty next.
    HJ, the threads had that much slack, that I made 3 rounds of tape and i could still thread it with relative ease.
  8. Elijahwww
    Jan 25, 2014
    MA
    That worked, plus more putty on the drain collar threads, where-about the bottom rubber washer is. It wasnt keeping the seal otherwise.
    Is there a safe torque spec for the lock nut? I was afraid of cracking the sink or bending the flange.
  9. Elijahwww
    Jan 25, 2014
    MA
    Still no leaks, thanks everyone
Similar Threads: Popup drain
Plumbing Forum, Professional & DIY Advice Extension Terminology for Popup Drain Jul 7, 2014
Plumbing Forum, Professional & DIY Advice two faucets one drain sink...can i use faucets with standard popup drain? Dec 10, 2013
Plumbing Forum, Professional & DIY Advice Popup drain plug doesn't Oct 21, 2006
Plumbing Forum, Professional & DIY Advice Bathroom Sink - Popup - No Through Pivot Rod Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Proper sealant for popup? (faux marble) Apr 21, 2008
